YOu should put a block to metal in there to help fill and absorb a blow. In case of bad luck sombody hits that spot it will crack, or you could use that fiberglass/ bondo.
hmmmm.....
when i get my 6 painted next summer im pondering if i want to shave it all the way around. guess it will come down to how much cash it will cost. thats the labor, and also the price for the electrical components of the door opener, and trunk opener.
solar
that much bondo will be too much. it will crack from the slightest impact and is looked down upon. also, someone could break into your car easily just by knocking out the bondo hole and unlocking... simple.
you will definately want to weld a metal piece the shape of the hole in there and grind it down... then bondo and paint...
