It is easy to change the shifter bushings at the bottom of the shifter, and on the shift rod coming out of the tranny, but I noticed while under the car the other day that the front part of the linkage coming from the shifter has a pin, not a bolt, that retains the bushings.
Can this be easily pressed out, or is this area meant to not be serviced?
