I installed a PRD short shifter a couple months ago and every since then my shifter is very loose. When it is in gear it can move from left to right like it is in neutral. It did it a little bit with the stock shifter in but never this bad. Can anyone tell me what is wrong?
Try tightening the nut on the bolt that holds the PRD onto the shift-linkage. Maybe nut has loosened itself or is missing...
Yes, you probably need to replace the bushings, but try this first.
