Hi, im new here, and very excited that I found this page! Im from Puerto Rico, and just got a 1990 GT
As with all used cars, some things need to be fixed! The car has a problem with the shifter, its loose, you cant really get the gears easily, and because of it is the first problem Im willing to adress!! So if any of you have had this problem, help!!! After that, is fixing the a/c, and then its performance mod time!! I want to run 13 sec 1/4 miles!! Thats to compete with my fathers acura turbo(runs high 12's) and my brothers celica gts(runs mid 14 but his planning on nos)!!
So all your advice will be greatly apreciated!!
And anything I can do for you, jusy ask!! I know alot about turbo, and turbo set ups!!
Does the shifter have excessive wiggle and play when it is in gear? If that's the case, just replace the shifter link bushings and it should help a bit. Shouldn't cost that much either. That's the first thing I would try.
