How does double clutching help the 1-2 shift, and what's the technique? My understanding was that double clutching was only used to downshift.zakaron said:When its cold (early morning) 1st to 2nd will give a little grindI find that double clutching helps and will rid the grind; all other gears are fine.
When I shift out of 1st I put it in neutral then let the clutch pedal out while in neutral, then push clutch in and shift to 2nd. It helps spin the gears up when going into 2nd. Unless this is the wrong terminology for the technique I used! Whatever its called, it helps get rid of the grind. Someday when I'm not busy with the Z I'll put some Redline in and see what gives.Mike 93LS said:How does double clutching help the 1-2 shift, and what's the technique? My understanding was that double clutching was only used to downshift.
there was a thread on that before...ill find it for youSolarSlash said:double clutching when downshifting? why is the purpose of it?
SolarSlash
