im thinking since you don't have an hub adapter, they are not centered on the rotors well at all.
p.s. tell santa i want more boost
If they center on the lug holes though then the center hole is a moot point.im thinking since you don't have an hub adapter, they are not centered on the rotors well at all.
hRrrmmm... maybe a problem with the VSS (Variable Speed Steering) system?and it doesnt really jerk except for that first time. basically the steering is so over sensitive the slightest touch and it goes further than it should. basically if it takes say 5lbs of pressure to turn the wheel it takes me 1/4lb... its really ridiculous at highway speeds
