Not, to burst anyone's bubble, but it's pretty easy to modify the stock shifter for shorter throws. All you need is a small piece of steel tube stock the same diameter and thickness as the shifter bushing housing. Cut it to the same length as the bushing housing. Have a local shop weld it to the bottom, parallel to the original housing. Voila, you've lengthened it approximately .8" and shortened throw 40%, the same length as the PRD(you'll need new bushings). If you want to reduce stick height, simply cut off all but 4 threads from the top and grind off the lip right below the threads. The neat thing is that you can return to the stock throw by using the upper bushing housing. Total cost for mine was $0. I found the steel tube in my garage. I upgraded my shifter bushings to Delrin units made by a fellow PT.com member for $10, got rid of all the slop/play in the shifter.
