does anyone no of a short throw shifter for a '93ls thanks and if so how hard is it to install, thanks
s-e-a-r-c-h
save time and help yourself.
Go with the STS from Rafi.
you can get a sts on ebay for a civic. check out the 2nd gen project. someone just did this and its fairly easy and also the civic sts on ebay are like $10. check em out.
I was playing with this idea the other weekend. I already have a short shifter so I decided to make it even shorter. I just used 2 peices of aluminum and I extended shifter linkage. Can you say SUPER short shifter. The only problem I had was the way the shifter is bent it would hit the plastic edges around the center console.
