1 - 15 of 15 Posts
Can somebody give me some info on what is involved in installing blinkers on the front quarter panels above the LS logo?? I have seen a few 6s with them and I think they look great!:cool:
They have different side markers available. Some only involve drilling a hole big enough for the bulb and wire to go through and then you just drill 2 screws into the body and that pretty much fixes it to the car. In my opinion, these are cheap and don't look that great. The ones that I have required me to cut a hole almost the size of the fixture in the panel of the car. It is not a flat piece but an enclosure similar to the stock sidemarkers. The hole was cut very easily with a dremel and a cutoff wheel. Wiring is a snap unless you want to go all fance and have them blink out of sequence which would require a relay.
Jorge,
Your sidemarkers look really good (Factory like)!
What brand are they and where did ya get them??
Thanks.
Rye
Thanks anyway Jorge!
Could you tell me the shop name and address?
I get over to Jersey a lot for work, maybe I can swing by.
Thanks again!
BTW - Your car is hot! Like your web site!
I'm sure I'll have more questions for you!
Rye
So how do I know what to ask for so I don't get the cheesy ones that you mentioned? Do yours blink at
the same time as your normal blinkers?
Thanks!!
Thanks for the lead!
Looks Promising!
Thanks man!
Discussion Starter · #15 ·
Mine are being installed as we speek, I will post a pic when they are done. I am sure they are the good ones, because he said they were the kind that took 2 hours to install. :D
1 - 15 of 15 Posts
