Someone suggested using silcon spray lubricant on the window guides to make the mechanism work better. Well I did this and it works great. I also lubed my sunroof mechanism and it slides really fast now - awesome. But the best was doing my door hinges and latches. It barely requires any force at all to shut my doors now. They click shut very lightly like a new car with a high quality feel.
I used STP Silicon Spray in the red can. You guys should check it out. I used to use WD-40 on everything but this is way better.
However the sunroof still doesn't tilt whithout me pushing up on it. It comes really close to tilting on it's own (it will do it if it's not quite closed all the way. But otherwise I still have to push it up with my hand. I think the tilt thing is just worn so the motor isn't getting enough leverage to start the tilt. I've gotta give it a little help and then the motor does it fine. Oh well my car has been this way since 97k mi.
