good call on the RR-Racing deal... i should have took advantage of that when i did mine along with the ze swap. as u can see in my sig, i have the rr inserts and mx-3 flywheel with ACT clutch.
i haven't driven on a fidanza.. i kinda regret having the lighter mx-3 flywheel, because i don't actually race my car much. it creates quite a bit of discomfort during everyday drives...
it's requires more skill when starting on a steep hill, otherwise u'll stall the car. RPM also needs to be matched closer during shifts otherwise it makes a nice jerk. Or if you're very unskillful, u'll stall the car. i can only imagine the fidanza would magnify these effects. Good luck parallel parking on a steep hill.
the engine seems to vibrate more on clutch engagement, and is not as smooth. then again, it might be the ACT clutch grabbing a bit harder than the stock setup. all in all, i think my ride can just be described as 'rough' with this particular combo.
keep in mind that i'm 26 years old today, so this is an old man's opinion. some young man like yourself would probably prefer the rough ride.
