Seems that whenever I have a problem, other people open up and seem to then share and say they had the same problem. Well thats nice to know after the fact... Anyhow, 2G clutch, but figured I'd get some thoughts around here.
I've had this clutch combo (ACT HD PP and Spec 2 disc) for about 5k miles or so.
A couple thousand miles ago, I was like driving along, push in the clutch, pedal stays on the floor. Pop the hood to see a burst clutch line. Replaced it, bled it, all is fine and back to normal.
I just finished a new turbo kit and go out driving. The gears progressively get harder to shift into, like the clutch isnt disengaging all the way. With the car off, tranny shifts fine. So, I grab some wrenches and screw the rod in on the pedal a few turns. Now its good again. Drive 5 miles, gets stiff again. I repeat, and its fine. I did this until finally I hear a pop and the clutch wont disengage at all. I go under the hood, slave cylinder is pushed so far out, the plunger rod fell out.
So, basically the clutch fork is depressed all the way and the clutch wont disengage.
Its one of 2 problems here. Either the clutch fork is bent, or the pressure plate is somehow trashed. I have never heard of something like this happening. Any insight?
Either way I have to pull the tranny.... these [fizzle]in cars are worse than DSMs if you have any sort of power. Its pathetic.
I thought ACT was "the best?"
I need something to take 500 whp without slipping or busting trannies. I had a spec 2 and when I had a measly 300 hp it slipped. This one took about 400 hp, now this. WTF. What now?
