Ok here is the problem, for some reason the passanger window switch on the driver side is not working properly. Everytime when I use that switch to roll up or down the passanger side window, it moves very slowly like there is not enough power to push the motor. The strange thing is that the driver side works just fine, and if I used the passanger side switch it will work OK.
I have Clifford alarm with window and sunroof roll up option. I'm not sure the problem is on the switch itself or could it be because the window roll up module.
HHHEE...HELP...p...
Thanks
HHHEE...HELP...p...
Thanks
