Guest
i just finsihed cleaning my car, i started it up and the deck would continuosly go on and off, i can't think of anything i could have done for that to happen when i was cleaning the car, now the stereo won't even come on at all, the car has a new battery, so i don't think that could be the problem. i checked the back of the deck and all the wires seemed to be where they should be.
it is a Sony Xplod xr-c5300x in-dash am\fm cassette deck
any help would be appreciated.
Fowad Zarify
Did you wire it using an aftermarket harness, or did you wire it yourself into the fuse-box?
Make sure all ground wires are secure. Maybe if you have amplifiers, make sure their connection on the positive post of your new battery is tight and without corrosion. Don't know what else it could be.
