Ok, I was wondering if anyone knows any info on these turbos (compressor a/r's). It's a Garrett AiResearch Diesel turbo. It's blue and the part number is G84698C91; model number is T04B25. My friend's dad just handed it to me and said "here, have this" and I was in shock. It's a bigger turbo, and is there a lot of customizing involved in this (worth the installation?) Sorry for all these turbo posts
To be honest you should really start posting this stuff in the "FI" forum.
As far as the turbo is concerned, I believe diesel turbos have a huge turbine in comparison to their compressor wheel. The turbines are just way too big to have for a daily driver, and it's basically overkill. You would probably have to get through 2nd gear before you made any sort of boost.
With a high boost 4 cyl, you want a decent sized turbine but a much larger compressor. That's where the term T3/t4 comes from. You use a smaller T3 turbine mated to a large T4 compressor. This gives you less lag but flows plenty of air for top end. Now, what you should do is get one of those .60/.63 T3's from the junkyard and use the bigger diesel turbo parts to make yourself a hybrid.
Nah, it would very likely be too big of a turbine for an Fe3. A straight T4 diesel turbine is too big for any 4 cylinder. You're better off going with a clipped T3 wheel and housing. Not to mention, that T4 doesnt have an internal wastegate does it?
The DOHC is not the only reason you would want a bigger turbo, but rather the target boost you want to puish efficiently.
