What size speaker would fit in the back ports n screw right it with no pron i know the ones that are in there are 5 X7 but they have those gay as plastic brackets which make them bigger n my brackets r broken n u can buy them seperate at mazda but i was told that the brackets make them 6X8 is that correct?
thanks
The Full Dong
6X8 will fit. That is what I have in there all around. For future reference there is a Car Audio forum. :)
Stock MX's are 6x8s all the way around. The rear ones are usually dry rotted when you find them failing as sunlight gets them pretty good. if your brackets are rotted too, i'd say you're in quite a sticky situation. i'd contact the dealer and see what your options are.
