Anyone know how or where to obtain the "Self-Diagnosis checker for the MX6? It's the one the Mazda dealers use for checking various systems in the car. It's referred to a lot in the workshop manual. The part number is 49 H018 9A1 if that helps. Any help would be greatly appreciated.
Thanks
i've had it explqained to me, and you should be able to make one with an LED and a paperclip... Pacman was gona make me one :D
if you have a look in the 2ndgen FAQ there is a bit there on codes and testing them. Its basically an LED blinker light, should cost you like 2$ to make and will work just as well as this mazda code thingy
If your car is Pre 94 then you dont need it you just use a paperclip and a 12v lamp but if it was build after mid 94 the computer is the OBDII standard and you can get an OBDII reader from ebay
The "ODBII" 2gens wernt technically a ODBII, so those readers dont work properly, the paperclip trick still works on the 2's though
