I need to fix my spoiler brake light to pass inspection. 94 MX6 LS. I have some questions:
1. I cracked the plastic piece that goes on the back to seal the LEDs from water. Can I rebuild it with some glue and sealant?
2. The strip broke because some of the LED pins rusted (you could see moisture inside the strip). Am I correct in assuming that I can get fresh LEDs at radio shack and do a fresh solder and the strip would work? They are in series so they all need to work correct?
3. Anyone have a wiring diagram for these things? There is one resistor and a few pins I can't identify
4. Am I better off just spending the 60 bucks to get a new light?
5. How do you get the power cord from the light strip to go through the hole in the spoiler into the trunk. I am feeding it in there without obstruction but it doesn't come out the other end??
