1 - 8 of 8 Posts
whats the fastest time you ran in your GT Turbo.
Me a 15.595 @88.7 mph. I would have probably done better if I had a better start but the first 2 runs it popped out of first do to either the kanifillar pins malfunctioning or the track was really sticky(you guess). So the 3rd run I walked the clutch and puleed that time. anyone else best runs?
15.0 @ 92mph with a 2.1 60 footer.
ZombieSS ECU Chip, and 10 psi.
-Zook
[email protected] -- 2.3 60 ft. (3900 ft elevation). 100% dead stock (stock boost, stock chip, no decals).
[email protected], with a 2.060 60'
stock turbo, 14psi, ECU, exhaust& test pipe, K&N filter, msd blaster II, a few small other things... 75 lbs lighter, on a 55 degree night... bridgestone potenza re-950's with 18psi in them...
its been my experience that instead of flooring it the instant you let off the clutch, wait just a millisecond then floor it. to get my 2.060 60', i revved at 2800rpm, when the second yellow came on i dumped the clutch and THEN i gunned it...
i've tried higher RPM launches...its just a massive burnout resulting in 2.4-2.5 60's and MPH's over 100
-Eric
1 - 8 of 8 Posts
