I got off my ass for once and made my own brace today. Cost me $6 in materials. I bought a length of .25" x 1.5" plate steel (you need it at least 61cm long), then drilled two holes in it (exactly 57cm apart) with a 31/64 (not a typo) metal drill bit. Then I finished the ends with a file, cleaned it with simple green, and sprayed some primer on it so it wouldn't rust.
Here's how it came out:
http://users.clas.net/~mcdonald/james/mybrace.jpg
It works real good - I can definitely tell a difference in that the back end tracks around corners a lot better. I'm pretty sure it's stronger than the stock piece too (though heavier).
To install you'll need a shallow 21mm socket, any 17mm socket, two ratchets, and a breaker bar.
Manifest:
Do I remember correctly you saying once that you had to drop the rear subframe to intall your corksport tie? I didn't have to do that.
[Edited by antiSUV on 05-18-2001 at 02:17 AM]
