I did the GND and TEN trick to get CEL codes. I'm having trouble reading one of them:
I got: 4, 12, 15, 17 then "11"?
The first four codes were easy to read. The last code which followed 17 was a long blink followed quickly by short blink that was inconsistent in timing from the other codes. Usually you get long, quick pause, short. I got long short.
I can't find any relation to a code 11.
Anyone have any ideas?
Thanks!
JLMx6, The codes are issued in numerical order, so i doubt its an 11. I susspect its the end of codes notification, before it cycles through them again.. Does it then have a pause and start with code 4 again ?
Oddy.
I made the same mistake - the double slow blink indicates a starting digit of 2, as opposed to 1. So, for instance, if the dash did:
LONG BLINK...LONG BLINK...SHORT BLINK...SHORT BLINK...SHORT BLINK
Your code would be 23, or an O2 sensor error. Make sure you look for the four second pause between codes.
Kris
