First off you will have to drill a hole in each of your headlight buckets (.5inch maybe or whatever the instructions say), to slip the strobe down inside. Then you will need to find a place to mount the transformer to. Make sure it is secured pretty well with either double sided tape or screws or both. Then you will need to hide the wires running from the transformer to the strobes itself. And remember to hide them good because wires are ugly. Then you will need to find a good ground to gound it out to. Just look for pretty much any body bolt under the hoodand make sure there is no paint/rust on it or it will not work properly. Then you need to run a power wire from either your battery or the fuse box. I would lean more towards running it out of the fuse box because it is protected then, but make sure it has power all the time, like the hazard lights or power seat. Run that wire from the fuse box to a swithch, and run the wire from the switch to the transformer, which should already be connected in the tansformer. This should help you a little bit.
Ken
