Does anyone know if GC struts fit a GD? cause these are the prices I got:
Supercheap: $101 each front, $94 each rear
AutoBarn: $150 each
AutoPro: $190 each
OUCH!
thanks.
PS they will be used with Low Kingsprings
You might be able to custom fit it. I asked this seller guy and he said its possible to use the 2nd gens on 1st gens if the holes are drilled a bit more and kinda customized.
By "each" do you mean like the front top strut bar and the buttom sway bar or am i just getting it wrong?
http://www.whiteline.com.au/
Whiteline products can be purchased through the following preferred outlets. Many of these are also suspension specialists that can give you expert advice.
SA
Autobarn
Click here for store locations
Car Torque Products
Little King William St
rear 74 North Tce
Kent Town SA 5067
Ph 08 83627667
Fax 08 81321706
Email: [email protected]
Bridgestone Tyre Centre - Noarlunga
10 Goldsmith Drv Noarlunga Centre
Adelaide 5168
Phone: 08 8326 3433
by each i mean the strut/shock absorber.
so 190 X4
ahh i thought you mean top struts and the buttom sway bars...anyways....
emm...yeah the front 2nd gen would fit but not bolt on as I have heard....the holes must be drilled and adjusted....and they are heaps cheap on ebay and there is plenty of it usually in ebay australia....
