sts-99
It's kickin'. Greg's right, not much visually, nobody will notice, but it is a lot more fun. Anyway, your question:
The bolt isn't too bad to get to, but you'll need a 10mm deep well socket to get to it.
My suggestions are such:
Before you put this bitch in, go buy a 10mm deep well socket and some (damn what are they called?) the pliers to remove the little ring things. I did it without the plier things, but it sucked and there were three of us getting those bitches out. To get to the linkage bolt, remove the flash metal around the cat/s-pipe. That's what you need the 10mm for. And leave the car in 4th (or whatever it was, it's on the probesport directions.) Then just undo the bolt.
But don't forget those damn pliers, they will save your ass.
