I think that someone should make like a performance dictionary for all of the members(specially the new ones) Its kind of hard to now what some Abbr. and words mean when you first start...
(I think it might be useful)
COnsIder THis...
THankS
:eek: :eek:
· Registered
I have never seen one, but that doesnt mean there isnt. Anyways, here are a few just in case the dictionary isnt around.
cai- cold air intake
tb- throttle body
im- intake manifold
wot- wide open throttle
sts- short throw shifter
Hope this helps, and I will post more later as they come to mind.
· Registered
TPS - Throttle Position Sensor
CPS - Crank Position Sensor
FMU - Fuel Management Unit
ECU - Engine Control Unit
FW - Flywheel
VAF - Volume Air Flow meter commonly refered to as MAF which it is not.
FMIC - Front Mount Intercooler
BOV - Blow Off Valve
WP - Water Pump
CR - Compression Ratio
TP - Test Pipe
TDC - Top Dead Center
VRIS - Variable Resonance Intake System
