1 - 18 of 18 Posts
My 1988 TX5 Turbo is due for another minor upgrade. I m wondering which is the better next step option?
1) Replace my stock cat convertor with a straight through one?
2) Woo's Chip?
My current mods are:
1) KNN Filter with cold air intake tube from side panel
2) Manual boost controller on 10psi
3) 2.25" straight through exhaust and muffler
thanks guys!!!
Actually no.. My G1 MX6 was at that time incompatible with woos chip..
But I have been in 3 MX6s with the ECU and it is fantastic .. particularly with the manual boost controller..
It basically lets you run a higher boost .. wickedy wick wack.. ..lol..
yeah, woos chip is very good for the money. your guarenteed aswell (money back) you'll like it. if u don't see it was worthwhile, tell barry and he'll give u ur money back, thats not going to happen with a cat.
but u will notice the difference, not as much as some people on here say so, but its definately worth the money.
First mod should definately be 3" exhaust and boost controller. Thats more than enough to run a 14. I would definately do exhaust and boost controller first. After that probably time to start saving for a clutch unless you are lucky.
i would generally agree tim, except for the fact, he's only given us the options of a high flow cat to match his current 2.25" exhaust. if he was prepared to save a little and do full exhaust or even cat back 3" then yes tim, i definately agree with u!
but if hes talking about a 2.25" hi flow cat theres still going to be so much restriction in that exhaust anyway.
in which case ill stick with the woo chip
Yeah I would say woos chip first. Still something to think about with the exhaust, 2 1/4 might be good on an NA motor, but really for decent (proven) power on an f2t 2.5 or 3" definately seems to do the trick :)
the ge i had had a 3 inch turbo back and a pod and it would hit boost cut with no othere mods..
prolly got to do somthing about the ecu both ways..
Mine ran fine with 3" exhaust and pod, about 9.5psi. Sure it didnt have a leak or someone had fiddled with the solenoid? I remember it was a modded car when you bought it correct?
Could have been.. it only started doing it with the pod..
It had an external bov :shrug:
It was turbo back and a test pipe for a cat..
Yeah I have the original elbow soon which probably doesnt help. If I were keeping hte thing it would be one of the first things to go.
GotF2TinGD can admit to the difference a 3" exhaust makes, I see him reading this thread...
i had 2.5inch cat back exhaust resontor where cat is. 9psi boost k&n panel filter and i ran a [email protected] !
i need another 4psi boost a t28 aftermarket ecu and my cooler isntaleld :p
nah tim only 2.5inch cat back.
really unless you want to keep your car a long time etc and change turbosits no point to get the front pipe done
unlessu just want the littel bit more of power id reckoment the front pipe
Discussion Starter · #16 ·
I originally went for 2.5" exhaust but I was also concern about too loud then attracts police. So the mufffler guy recommended 2.25", which I'm happy.
I called another muffler guy about doing a turbo back, he said it is no point unless I upgrade my stock turbo, and also upgrade my exhaust to 3".
This is why I came to the conclusion of either Woo's chip or replace a hi-flow cat.
I don't intend (at the moment anyway) to upgrade my exhaust to 3". I understand Woo's chip was designed for 2.5" to 3". Will it also benefit 2.25"?
it will even benefit stock
1 - 18 of 18 Posts
