well i have a KF-ZE engine with a 10:1 compression on it and i was wondering can i supercharged this engine with this compression and if so what would be a safe psi for it, also this may sound dumb but i'm not certain i was also wondering if you can connect a boost controller on a supercharger as well
you cant connect a boost controller on a supercharger... unless you use a pop off valve... but thats sorta different.
you can SC 10:1, the boost pressue depends on fuel used, intercooler efficiency, mgmt controls, etc...
The Full Dong
you can boost at that compression. Like Loring said, you need to make sure you have enough fuel to support your setup and make sure to get it tuned properly. AFAIK, the fastest trap for the KL series engines was done by My_Probe_Is_Faster with his turbo'd KLZE.
