So I still have a problem with my steering. I took my car to a reasonable auto shop to get a quote on fixing my car. First my symptoms, for those of you that don't know. My steering wheel feels a bit loose, and the drivers side front wheel clicks on slow, tight turns.
The mechanic says that my rack and pinion is a bit loose, but nothing dangerous, and my front strut bearing is the reason for my clicking while turning the wheel. That doesnt quite make sense to me... but I have never really worked on the suspension.
The auto shop quoted me 1500 dollars for parts and labor of replacing the rack and pinion and replacing the struts on my car.
That is WAY out of my price range right now, so I have moved on and desided that I am going to have to do this myself. I dont even know if this is even posible for me to do. I have all the tools I need, and a Hanyes Manual. That is if my friend let me use his stuff. Otherwise I will have to rent some things. I don't see anything on replacing the rack and pinion in the manual. The only thing I see is how to replace the steering gear. I am hoping that is the same thing.
So if anyone that reads this could tell me how to replace a rack in pinion on a 2nd Gen LS or what page to refer to on the Haynes manual, then I will shower you will karma.
I dont think that the click noise would come from the strut bearing. If this is possible then please tell me. Or if you have any other suggestions I would be so glad to read it.
Thanks,
Jake
Thanks,
Jake
