1 - 8 of 8 Posts
I ordered my Addco endlinks and a set of poly bushings for my stock sway bars. I recieved one set of the bushings so far and they're for an 18mm sway bar. I did a search on the sizes but I've seen different answers. I don't have 4ws. Does anyone know the stock sizes of the front and rear sway bar for a 1st gen? I know manifest had the part #'s for the energy suspension pieces. The part # I have for one set is the same as he mentioned but I want to make sure I have the right sizes for the front and the back before I get my car in the air. Does anyone have that info? Thanks
No, I already have the endlink sizes. I'm looking for the front and rear sway bar sizes so I know which size of bushing I need. I think I've heard 18mm for the back but I'm not sure.
Sorry, I still don't follow...
You should be able to get the two Addco endlink kits I mentioned above, install them and enjoy.
Alright, sorry I'm not being clear with this, I worded this question really crappy. What I'm looking for is the diameter of the stock front and rear sway bars for a 1st gen MX6. I want to make sure I order the right size bushings for the bar. I don't need any information on the endlinks. I have already ordered the Addco endlinks. Thanks again.
:idea:
Now I'm with ya. Damn Haynes manual says nothing about sway bar dimensions. Sorry. Are you getting them from Addco or Energy Suspension?
I'm getting the sway bar bushings from Energy Suspension. I guess I could just crawl my a$$ under the car and get out the calipers.
Front is 24.2mm (.95in), rear is 16mm (.63in). Unless you have 4ws then rear could be either 16 or 18mm (.71in)
If you don't have a GT then the front will be either 17.5mm (.69in) or 20mm (.79)
1 - 8 of 8 Posts
