Here's the deal. I noticed a squeaking coming from the rt/rear tire/wheel/brake. I Turned the rotor, and that helped, but the squeaking still persist, just not as loud. The squeak happens weater the brake pedal is pushed or not. FYI I replaced the pads about 4 months ago, and turned the rotor then. I've heard that brake dust can cause problems, but I cleaned up the ares. A little help please??
check your rotors
93's and 94's have problems with the rear rotors not releasing when the parking brake is released
just a thought
It could be the rear calipers not releasing. Do you know if yours have ever been replaced, because the 93's were one of the years that had the rear caliper problems?
