Things you will need to do to fit to a F2T:
3 flanges. 1 for the exhaust housing inlet. 1 for the dump pipe. 1 for the compressor outlet. You can get these cut up for about $50-60. Including one for the inlet.
Get a gasket set to suit the T25 from GCG Turbo's in Sydney. They are $50. you get 5 gaskets. exh housing in, dump, oil drain, compressor in, and compressor out. You can take these to a profile cutter.
4 flanges. 1 for the exhaust housing inlet. 1 for the dump pipe. 1 for the compressor outlet. 1 for the compressor inlet. You can use a standard 2" 2 bolt exhaust flange to mate it the the compressor housing.
Take the turbo and an F2T oil feed line to a line and fittings shop. Get a nipple that will fit the oil line and the turbo. Take some water line of the same diameter to that off the standard setup also. Get some fittings that suit the centre cartrige.
You can use a standard exhaust manifold, and get the flange welded on. As for the compressor outlet, if you intend on using the standard rubber hose, get a 1.25" length of 1 3/4" dia pipe welded to it.
The same applies for the compressor inlet, but with 2" piping.
For the dump pipe, it is best to use some 2.5" piping. Get it crush shaped to fit the shape of the turbo housing. Once the exhaust place has done the initial bend down past the A/C compressor, flair it out to 3".
Rough costing will be close to $800.
