SleepCounter said:
I'm not certain there's such a thing as a McPherson Strut suspension with negative scrub radius.
im very very sure all (road approved) vehicles have negetive scrubs radius
it is far safer
http://www.jags.org/TechInfo/2001/08Aug01/scrubradius.jpg
take a look at the apposing diagrams
the srub radius is the amount of axial movement in the suspension
negetive scrub shows the steering axis inlination (SAI) intersecting above the road surface alowing
postive camber change this allows stability
how ever
positive scrub shows SAI and vertical tire line intersectin under the road surface (this is waht happens when you lower your car with out proper change in control arms) it alows a
negitive camber change = less stability how ever more adherence to cornering forces
it basically means as you go towards more positive scrub you will have the
POINT of LOAD moved further away from the
POINT OF CONTACT
:jump: actually next meet ill lend some steering and suspension module for anyone that whats to borrow it
