Hey all,
My girlfriend wants to buy an MX6. It'll be her first car,
so looking for something reasonably reliable. I haven't
heard anything bad about the MX6, except to stay away
from the automatic tranny. :)
Aside from that, is there anything I should look for
when helping her buy an MX6? Anything typical
problems that occur that I can watch out for, etc.?
Any help is appreciated.
TIA,
Mike
if there is oil in the plug wells then it needs valve cover gaskets, and if they haven't changed the timing belt yet try to knock off a few hundred on the price saying that you need to do a bunch of maintenance on it. as far as other things check out this website for all the info you need:
http://www.bradbury.cwc.net/probemx/index.htm
Okay, so, more or less, check for oil on the plugs... Timing belt... Rear calipers, ignition module and things of that nature are going to be evident...
And mostly on only pre-95 cars? Sweet. I'll go give it a lookover, and see how it looks. I think my only complaint would be the
yellowing headlights, and there seems to be lots of solutions
to that. :)
Thanks!
good luck. i read through that site at least twice before buying my six and i've learned many things since then as well for whenever i buy another car.
Basically there aren't any problems with the 4 cylinder models unless they are equipped with automatics (Ford boxes).
The igniter problem and rear caliper problem are only on 93-94 V6s. I have heard of some electrical problems on very few 93s.
For the most part these are very reliable cars, atleast my 95 V-6 has been. It's a 5 speed with 127000 miles on it, never a major repair. I have done valve cover gaskets and CV joints and that's it. The valve cover gasket repair will run probably $300 for both of them, but a mechanic or dealer will be able to tell you exactly how much.
The V-6s supposedly have different (Mazda) automatic transmissions; they may be better but you should still be cautioned.
The timing belt job is a must on the 4 cylinder engine; if it breaks, you can bend valves. On the V-6 it will not do any damage, but it's still an inconvenience as the car quits.
Just do a thorough inspection of one before you purchase, and if you have any concerns about a specific car, post them on the board and you'll probably get lots of help.
Tyson
