I HAD TROUBLE LINING THE BELT UP ON THE REAR BANK. THE PICTURE WAS HARD TO SEE. THE CAR STARTS BUT DOESN'T RUN PERFECT AS BEFORE. CAN I ADJUST THE TIMING OR DO YOU THINK THAT THE BELT IS A TOOTH OR TWO OFF?? IS THERE A BETTER BOOK THAN THE HAYES OR DOES SOME ONE HAVE A BETTER PICTURE. THANKS DAVE
since the mx6's timing is controlled by a knock sensor you can not adjust the timing, so if your knock sensor is good then it is most likly your belt (and its really anoying when people type in all caps thanx ;) )
