Hey i just took off my snow tire and put back on my normal tires. Only i have a problem with the front left tire. When i unscrew tyhe valve cap air leaks out untill the cap is completely off. And the PSI keeps going down. Im lossing air!! i filled it up to 34 psi on sat. and today its down to 29 psi. I checked but i did not see any leaks or nails or screws in the tire so I suspect there is something the matter with the tire valve itself. Any help would be appreaciated.
THanks
THanks
