I have not had good luck using a screwdriver to pop the door card fasteners loose on other cars, so I want to get the special tool that is designed for the job. Does anyone know of one that works well on the MX-6 door panels? Brand and number would be a great help. Thanks.
1. Remove the exterior clips and screws that are holding it on from the outside.
2. Pull on the door panel starting at the latch side of the door at the bottom and working your way across the bottom to the hinge side and then up
3. Once the panel isn't attached anywhere, bring the panel up to get it off the window area
my matco and snap on ones work great. i also have a hard platic trim tool that works very well.
