Guest
i have a problem i am in the process of turboing my fe3 dohc n/a engine. i aslo happen to ahve a rebuilt hiflowed toyota ct26 supra turbo im wondering if this turbo would be suitable to the 2.0 dohc engine i will have 9:2:1 cr once i change the pistons, also will have fully programmable ecu any suggestions??? thanks
A
Guest
Discussion Starter #2
seems fair enough... of course you will need to make a exhaust manifold but thats easy enough, oil lines, intercooler, and the usual gear.... you could probably do without the intercooler - but keep the boost down to about 4psi... with IC you could probably get up to around 7-9.... better to run too little then too much
and of coure some dyno tuning etc..
good luck! :)
This is just a suggestion.
But I would think that since you are turboing this motor for the first time, you should sort it out on a smaller turbo before putting the bigger Supra one on.
