the MX-3 gear ratios are exactly the same except for final drive which is 4.388:1 for quicker acceleration at the cost of lower top speed and maybe less mpg. here's the MX-3 gear ratios:G2 Racer said:Now my next question.
Can the MX-3 V6 Transmission ratios/gears fit into the MX-6 V6 transmission?
no u wont. its not going to be a direct swap. the probe tranny however would be a direct replacement and has the same gears as the mx3 tranny.G2 Racer said:Thanks,
I might just swap an mx3 tranny in.
why wouldn't it be a direct swap? one thing I'm not real sure on...the probe has taller tires on it, wouldn't the speedo gear be set for that taller tire?Aussomea said:no u wont. its not going to be a direct swap. the probe tranny however would be a direct replacement and has the same gears as the mx3 tranny.
