That sounds like a cool idea, but the question is, do you put the cooler before or after the cooler? I think it should go after, to take away the heat that the turbo puts into the oil, but maybe it wouldn't make a difference if it were before or after, if the same amount of heat is taken out of the oil either way.
Our cars do alreday have oil coolers btw.
I was thinking about before... the oil coming from the engine is already HOT, so the cooler would lower the oil temp. just before it goes into the turbo so that way it can absorb more heat from the bearings.
The stock cooler we have just cools the engine oil with the coolant from the cooling system... so its not THAT effective!
Wouldnt this restrict the oilflow to or from the turbo to mouch. when i read abouth turbo conversion i found a chapter abouth oil piping to and from the turbo the drain pipe from the turbo should according to this have as free flow as possible. im not shure of what will happen if you put an cooler in this pipe but ill guess it will restrict the flow a lot.
what abouth install a air/oil cooler and attach the tubes at the filter socket with an adapter
I'm not sure it will create backpressure... oil system pressures are pretty high (I mean look at the flimsy oil holes the oil has to go thru in the filter!!) and a tranny cooler was designed for that kind og thing as well...
My friend is going to but a Subaru XT6 (a flat 2.7L 6cyl.) Motor in is 87 Subaru wagon (which has a flat 1.8L 4 cly.) and then put one of his Mitsu. Conquest turbos on it and he was thinking of putting pre and post oil coolers for the turbo charger.
