Hey there
So me and any my buddy are turning the 6 into a track car just for fun. Got the Ebay turbo kit which came with 70 % of the stuff you need to get it running. As we're trying to get the items to get this turbo running, I find king6's step by step turbo install. The first thing to do, he says, before anything else is fuel pump upgrade to 255lph and bigger cc injector and get a megasquirt.
The turbo was already on its way and buying a megasquirt was out of the question. I've gutted Klze Intake manifold removed the egr valve, the Idle air control under the TB and charcoal canister. I didn't replace the fuel pump nor the injectors.
So we've got the turbo running... well kinda. It'll idle above 1000 rpm and it'll red line no prob in neutral as well as first gear. In second and third gear the turbo will spool up and start picking up speed but as soon as hits around 4000rpm the motor just stops responding and the blow off valve goes off.
So what do you guys think? opinion and suggestion. Is it the VAF (not enough air), not enough fuel, or is a computer thing (megasquirt).
