1 - 20 of 25 Posts
What description of the turbo oil feed line can I give a shop for them to make one that perfectly fits our turbo ?.. like the length an stuff like that. ( oh and I heard like anyshop can make me one like a break shops is that ture ? )
it doesn't exist
oh I dont have one.. I was just told to go to a turbo shop and ask for a high temp, oil resistant hose with AN fittings , so Ill just try that.. how long should it be ?
its not rubber.. I think its called "braided steel" or something.. so I could move it around and stuff idunno.. ok ill try the webpage thanks
Braided steel is not stock -- stock is a pre-bent hard steel (stainless steel) somewhat like a brake line.
I'm betting the stock part (even a brand new stock one) would be considerably cheaper than aftermarket braided line (and fittings).
Is this the stock IHI in the stock position?
Are you driving it with no oil feed or is it just parked?
yea its the stock turbo.. im driving it with it taken out .. so now im tyring to track everything down to put it back in.. hopefully this is the last thing I need to get.. is there anywhere I could go for like a listing for everything I need to put it in ?
ok I went looking and I heard I could use one of these.. so which one do you guys suggest ?.. and I need one of the cheapest one they have
Click here to see them
Don't worry, it won't be turbo for long.
~Chris
You can get a pipe bender for small pipe for $15 at any autoparts store.
They will usually even put a fitting on a piece of pipe for you there.
It doesn't get much simpler than that.
EDIT: Or better yet, I'll sell you a stock oil line for $15 Shipped. Paypal me if you want it.
Discussion Starter · #14 ·
~Chris
lol I meant.. yes I have the stock turbo, and im driving the car with no turbo in it. I want to buy it from you flyswat but I dont have paypal..
Discussion Starter · #17 · (Edited)
oooo really.. what AN do I need 4,6,8, or 10.. and you are 100% sure that those braided steel hoses can take the oil and temperature right ?
Discussion Starter · #19 ·
but u are sure I could use one right ?.. do you know how long it should be ?
1 - 20 of 25 Posts
