1 - 1 of 1 Posts
I figured I would post these up to help anyone rebuilding. Without going into the process images can still be helpful.
Do take note that if the bearing raceway next to the hot side ends are worn or the corresponding housing is worn on the outside a rebuild will not work without replacing the turbine and or the housing. Also note that the semi-circles on the inside of the wheel and the turbine should line up. I had mine balanced, but that is where they lined up balanced with the permanent marker line as the indicator. The used turbine pictured below would not work, but the casing did work. The float bearing didn't have holes and lead to the casing oil passages being blocked which cleaning of these passages is a must when rebuilding. The oil passages are tiny.
[/IMG]
1 - 1 of 1 Posts
