Ok, I read that if you don't use the HKS harness that you just splice the 3 ignition wires in, easy enough right? WRONG!
I took the steering column cover off and looked and saw bout 4 connectors. I read that you splice like this:
RED -> BLACK
GREEN -> BLACK/WHITE
BLUE -> BLUE
Ok, I found a BLACK wire and a BLUE wire, but not a single friggen BLACK/WHITE wire!
I looked at all the connectors, since no one has specified which connector is the one to be used and there is no BLACK/WHITE wire.
The closest thing I could think of is to splice into this BLUE/WHITE, but I thought I would post here first.
Hope someone can shed some light on this whole ordeal.
Thanks
-Zook
RED -> BLACK
BLUE -> BLUE
Thanks
-Zook
