Guest
·Guest
Is it possible to put a turbo in a mx6 with a v6 because their is not a lot of room under the hood? What kind could I use without having rebuilding my engine and is it worth it?
Yep. It ain't cheap, but it's doable. Most installations relocate the battery to the trunk and put the turbo up near the distributor. A little 16G running 7PSI would give you 220HP to the wheels on a stock-internal engine with little in the way of reliability concerns.Speed Demon said:Is it possible to put a turbo in a mx6 with a v6 because their is not a lot of room under the hood? What kind could I use without having rebuilding my engine and is it worth it?
