1 - 11 of 11 Posts
I'll take another pic when I get home. Whatever it is, Turbonetics did it.
How long was it used for and what kind of shape is it in? Does it need any work and is it a direct bolt onto my car? What are the specs on the turbo itself?
It appears to be a T Bird wheel in a VJ11 housing. As for the stock VJ11, the compressor wheel has an outer fin of 36mm and an inner of 37mm-tip to tip.
In comparison, the T Bird compressor wheel has an outer fin of 39mm and an inner of 40mm- tip to tip
Both have an outside diameter of 52.5mm.
You can easily distinguish the T Bird wheel from the VJ11 as the inner fins are more prominant. Both wheels have the same 5x5 fin setup.
T Bird wheel^^^^
VJ11 wheel.................^^^^........................VJ5 wheel ^^^^^^
The turbo was check by turbo city and they said it was A Okay
The only reason I am selling this turbo is because I want to buy a 2gen
KiNg MaRtY said:
just need the time and I'll get the pics. I usually post from work
X2:D
I am kind of haveing second thoughts on selling it though. I might not be getting the 2gen that I was looking at:)
1 - 11 of 11 Posts
