Ok I just changed my rear calipers with slightly larger mazda 6 ones (bolt right on). I am still using my stock disks till shops open up. My original caliper is rooted, leaking. When I pump the pedal up with pressure, it pumps up but then I let go for a few seconds, put foot back down and goes straight to the floor. Also when I press the brakes down with the car on, no pedal pressure whatsover, but the brakes still lock up.
It did not do this with the old calipers. The stock disks are a bit smaller, but this shouldnt make a difference right?? I changed my master as it was leaking as well, but it did this both before and after caliper change.
Chucked the stocker back on, almost done. Ill be at the cruise no worries, will let you know if I cant, but I suspect it should be ok. Leak or no leak, im coming. Just wont drive hard so I dont kill my self (or worse, my car).
Dad says one of the valves in the master cylinder is failing or one of the seals is in backwards, its a problem hes seen before, and hes been hooning for over 40 years.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
Mazda MX-6 Forum
