· Registered
Hi, I intend removing the stock air box and installing a universal K and N cone filter, does anyone have the part number for that cone filter and is it difficult to install?
Help will be much appreciated
Thanks
It's pretty simple to do, just unbolt the stock intake unit all the way up to the VAF then clamp on your K&N...although you will be getting hot engine air. I suggest you make or buy a cold air intake.
Anyways I got a universal K&N cone filter from summit racing for like $30 and the part # is GA RU-3130.
Hope this helps.
· Registered
its easy to install but i dont have the part# check summit racing's website. i have the B&M dual element with the chrome trim. youre luck you dont have the 4-cyl. i had to relocate my intake temp sensor. (its in the airbox on the 4s)
· Registered
You could just get any kind of 3" Cone filter. Some companies like K&N Will advertize a "K&N Filtercharger Kit" and charge like over $100 for it. then when you open the box, it's just a plain old 3" cone filter. I had K&N now use APC. Same thing, different color...
