1 - 17 of 17 Posts
Valve Cover *update*
I'm about to replace my Valve Cover gasket. I know how to do it, I'm just making sure that there is nothing "special" I need to know before I do.
One thing I don't know for sure, do I need to use a sealant (silicone) and a gasket, or just a gasket?
Just did mine on my 90 GT last weekend. Nothing real special about it, I didn't use sealant, but oil is slowly gathering around the right side half moon for the intake cam at the corner where the half moon starts to go up, so I would suggest using some sealant in the 90 degree uprising corners.
Ryan
after i changed mine, and used sealant, it still leaks along the back side of the timing belt cover. probably going to have to change it again. just be-careful with the sealant and try not to put to much on to get into the inside of the valve cover.
Smachan and Importhead, did you guys torque the cover down too? And Importhead, did you seal both sides of the gasket?
Ryan
[Edited by rmtaylor on 02-20-2001 at 08:54 AM]
When I had my '91 LX I had to replace the valve cover gasket, and was still clean when I traded it in. I bought a rubber gasket and just layed it into place and followed the torque sequence as described by the Haynes. I didn't use any sealant on it. Just remember to only tighten each bolt partially, then go back and tighten each one a little more and finally tighten each to torque spec.
Just be glad its not the oil pan your doing...
Well, I replaced it, no one warned me how easy it is to break the PVC valve! Oh well, I put in a new gasket--the old one felt like ceramic (it is supposed to be rubber). I put in a new one Sunday, now instead of seapage, it's freakin' spraying out (i'm exhaggerating a little). So I said to hell with it, and took it to my mechanic. I've replaced many valve cover gaskets, this is the 1st time I failed! My ego is hurt...lol
just got off the phone with my mechanic. I told him I lost the oil dip stick, he said that if it has too much oil in it, then that may have blown the gasket. That dipstick is $40, and I can't get it till Wednesday!! Man, this just ain't my week.
You sure you tightened them evenly man?
Yeah I broke two PCV valves on this thing before. They don't like cold weather much either, but its good that they're inexpensive. My car's going in today for a waterpump job so don't feel so bad!
Ryan
Discussion Starter · #12 ·
Yeah, that is probably around the corner (the waterpump/timing belt). Make sure you get that timing belt done--while they're in there. The manual says it should be replaced every 60K miles (I don't believe that-but), and it would just a smudge more in parts and labor--actually, they usually offer it as a package deal on our cars--since they are together.
Yeah, I tightened them evenly.
Well regardless of the waterpump, I needed to get the belts done anyway, it's been 60k. So it actually works out well. Except for the price, but hey I got the car for $900 I think I can dish out a few more Franklins to keep it going another 6 months.
Discussion Starter · #14 ·
Well, got it fixed. Since we didn't have a dipstick, I just had him change the oil (which was due anyway), and put the specified amount in. He said I must have had about 5.5 quarts or more in it!!
Dang, don't I sound dumb. But when you don't have a dipstick, and oil is spraying out, you tend to be a little nervous, and add oil--I added too much.
So it is fixed now
Discussion Starter · #16 ·
Oh, I guess I forgot to mention. He just put a new valve cover gasket in after changing the oil.
But dammit, I still smell a little oil here and there.
I think he treated me good. He put a new thermostat in there, made a dipstick for me (which he wants me to return to him--don't know why), and checked out the cooling system. My temp guage is off a little.
Charged me $97, which I thought was good. I THINK I'VE FINALLY found a GOOD mechanic--I think.
I'd put a 10k mile rule into affect. If stuff breaks before that, don't bring it back to him : )
1 - 17 of 17 Posts
