Has anyone tried or recommend the Venom Mass Air Sensor that they produce for the MX-6?
Anyone know the reasoning behind buying from them vs. getting a Mx-3? Also will it work with the KL-ZE motor?
Doubt it will work at all, IIRC its a generic part that you modify to fit your car. So to be able to fit it you the mx6 you would need to basically run a stand alone computer, and if you do that you should get one that is compatible with that engine management unit.
No actually Venom used to make a direct replacement MAF for our cars. They scrapped the idea cuase no one was buying them. They were a larger bore and didnt cause any problems...didnt require any reprogramming. They were nice, too bad they dont make them anymore.
Josh
The venom got spanked because it actually lost hp...
All it was was a hack for the most part.. They didn't want to do the work to optimize it and sales suffered...
Rob
