Leave the VRIS system alone unless you've got forced induction and have boost controlled switching or have a sheet-metal intake. The system was designed by Mazda engineers to make use of natural resonances that occur in the intake manifold all through the RPM band to maximize torque output of the little 2.5, which needs all the help it can get.
By monkeying with the VRIS, you interfere with these resonance effects and may lose torque. These guys who report their car was faster or gained somehow by doing this "mod" will probably almost universally find that their system was somehow defective (defective actuators, bad vacuum reservoirs or check-valve, bad or mis-connected VRIS vacuum hoses, defective solenoids etc) and all they are doing is getting back, in the RPM band where their tying suits, the power they should already have, nothing extra.
If they tie both sets open, then all they do is set it up so that they lose below 4250 and above 6250 but within that range, the engine runs well since that's what the PCM would normally have the valves set to then anyway. If they feel a sudden surge at 4250, it's because having #2 open from 3250 to 4250 isn't optimal and the engine is underachieving there. Then, at 4250, the thing hits its stride and goes like hell. They feel this surge and think it's more power. It's not.
